Publication date: 01/13/2026
Adjust the Axes
You can manually move or rescale the axis coordinates on a 3D scatterplot by clicking and dragging the axis. This option shows a different set of coordinates on the 3D scatterplot. It also lets you change the space that is displayed between the coordinates (or the coordinate scaling).
You can also specify axis properties by double-clicking the axis and modifying settings in the specifications window.
To move the coordinates on the axis
1. Hover over the middle of the axis.
2. Click and drag the axis.
To modify coordinate scaling
1. Hover over the end of the axis.
To rescale an axis precisely
1. Hover over the middle of the axis (the axis, not the label).
2. Double-click the axis.
3. Change the minimum and maximum coordinate values.
To hide data on axes
3. Click to deselect the Labels option for major or minor axes.
For more information about updating axes, see “Customize Axes and Axis Labels in Graphs” and “Extend Divider Lines and Frames for Categorical Axes” in Using JMP.
