Using JMP > Get Started with JMP > Platforms and Reports in JMP > Analysis Results in JMP Reports
Publication date: 01/13/2026
After you launch your analysis, the JMP report window appears. The report window shows the output of your analysis by using interactive graphs and text reports. See “JMP Reports”.
Figure 2.13 Report Window Features
