Design of Experiments Guide > Augment Designs > Augment Design Window
Publication date: 01/13/2026
In the initial Augment Design window, you can modify factor levels, restrict the design space, and choose augmentation options. The Augment Design window updates as you work through the augmentation.
• Factors
• Define Factor Constraints
• Augmentation Choices
• Model And Alias Terms
• Factor Design
• Design Generation
Figure 6.10 Initial Augment Design Window Using Reactor 8 Runs.jmp
