Predictive and Specialized Modeling > Bayesian Optimization > Bayesian Optimization Platform Options
Publication date: 01/13/2026
Image shown hereBayesian Optimization Platform Options
The Bayesian Optimization red triangle menu contains the following options:
Save Prediction Formula
Saves a new formula column for each response to the data table. Each new column contains a prediction formula for a response.
For more information about the following options, see “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP:
Redo
Platform Preferences
Save Script
Note: Additional options for this platform are available through scripting. Select Help > Scripting Index. In the Scripting Index, you can also find examples for scripting the options that are described in this section.
Image shown hereBayesian Optimization Model Summary Report Options
The Bayesian Optimization Model Summary red triangle menu in the Bayesian Optimization platform has the following options:
All Responses Profiler
Shows or hides the All Responses Profiler section that contains prediction profilers for each response.
Save All Model Fits Script
Contains options that enable you to save a script that reproduces the Gaussian Process model fits that are reported in the Model Summary and individual response tabs. This script does not reproduce steps performed in the Batch Selection tab. When the saved script is run, a new candidate set and batch selection are generated based on default settings.
Tip: Use this option if you are satisfied with the fit of the Gaussian Process models, but you would like to perform batch selection at a later time.
