Scripting Guide > Compatibility Notes > Compatibility Issues in JMP 19.0
Publication date: 01/13/2026
Multiple-Y Text Explorer launch return value
The return value of a multiple-Y Text Explorer launch is now a list of the created platforms. The new behavior is similar to how Contour Plot works, and is useful for those who want to send messages to platforms after launch. Prior to this change, the return value was a reference to the last-created platform.
Control Chart Builder Sort
The default sort for Control Chart Builder is now “Sort by Subgroup( 0 )”. Previously, the default was “Sort by Subgroup( 1 )”. Scripts that rely on the default behavior -- without a line of code specifying Sort by Subgroup(1) -- will behave differently.
Table Box Column Indexing
For table boxes that include check box columns, the check box columns are now included in the column index counts.
JMP Live Allow Download()
The Allow Download message has been removed from JMP Live objects. JSL will throw an error if the message is used.
JMP Live New Web Report()
New Web Report() can no longer publish to JMP Live. Instead, publish to JMP Live using New JMP Live Content(). See “Publish Reports or Data to JMP Live”. You can still use New Web Report() to publish to local files.
