Using JMP > Create Formulas in JMP > Edit Formulas > Cut, Copy, and Paste Formulas
Publication date: 01/13/2026
You can cut or copy any expression or an entire formula and paste it into another formula in the Formula Editor. Use the cut, copy, and paste shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu. The following aspects apply when you cut, copy, and paste a formula:
• When you paste the formula into another formula display, the formula appears in a formatted form.
• The formula is saved on the clipboard as a JSL statement. Thus, if you copy it into other applications, it appears as a JSL statement.
Note: Press Shift and click the red triangle next to the Formula Editor keypad to reveal a command called Copy As SAS Formula.
