Discovering JMP > Work with Your Data > Examples of Reshaping Data
Publication date: 01/13/2026
The options on the Tables menu (and Tabulate on the Analyze menu) summarize and manipulate data tables into the format that you need for graphing and analyzing. This section describes five of these options.
Summary
Creates a table that contains summary statistics that describe your data.
Tabulate
Provides a drag-and-drop workspace to create summary statistics.
Subset
Creates a table that contains a subset of your data.
Join
Joins the data from two data tables into one new data table.
Sort
Sorts your data by one or more columns.
For more information about these and the other Tables menu options, see “Reshape Your Data” inUsing JMP.
