Design of Experiments Guide > The Fit Group Orthogonal Supersaturated Platform > Fit Group Orthogonal Supersaturated Platform Options
Publication date: 01/13/2026
The Fit Group Orthogonal Supersaturated Design platform red triangle menu contains platform options.
For more information about the following options, see “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP:
Redo
Platform Preferences
Save Script
Note: Additional options for this platform are available through scripting. Select Help > Scripting Index. In the Scripting Index, you can also find examples for scripting the options that are described in this section.
