Reliability and Survival Methods > Fit Life by X > Fit Life by X Platform Options
Publication date: 01/13/2026
The Fit Life by X red triangle menu contains the following options:
Fit Weibull
Fits a Weibull distribution to the data.
Fit Lognormal
Fits a lognormal distribution to the data.
Fit Loglogistic
Fits a loglogistic distribution to the data.
Fit Frechet
Fits a Fréchet distribution to the data.
Fit Exponential
Fits an exponential distribution to the data.
Fit SEV
Fits a smallest extreme value (SEV) distribution to the data.
Fit Normal
Fits a normal distribution to the data.
Fit Logistic
Fits a logistic distribution to the data.
Fit LEV
Fits a largest extreme value (LEV) distribution to the data.
Fit All Distributions
Fits all available distributions to the data.
Set Time Acceleration Use Condition
Enables you to specify a use condition value for the acceleration factor.
Change Confidence Level
Enables you to specify the confidence level for the plots and statistics in the report. The default confidence level is 0.95.
Tabbed Report
Specifies the organization of the report. You can select one, both or none of the following options.
Tabbed Overall Report
Organizes the overall report into tab panels for the plots, comparisons, and results sections of the overall report. This option is not selected by default.
Tabbed Individual Report
Organizes the individual reports into tab panels. This option is selected by default.
Show Surface Plot
Shows or hides the surface plots in the individual distribution results section of the report. Surface plots appear in the Distribution, Quantile, Hazard, and Density sections for the individual distributions, and it is on by default.
Show Points
Shows or hides the data points in the Nonparametric Overlay plot and in the Multiple Probability Plots. The points are shown in the plots by default. If this option is unchecked, step functions are shown instead.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
