Reliability and Survival Methods > Fit Proportional Hazards > Fit Proportional Hazards Platform Options
Publication date: 01/13/2026
The Proportional Hazards Fit red triangle menu contains the following options:
Likelihood Ratio Tests
Shows or hides likelihood ratio tests for each effect. Each test compares the log-likelihood for the fitted model to the log-likelihood for the model that removes an effect.
Wald Tests
Shows or hides chi-square test statistics and p-values for Wald tests of whether each parameter is zero.
Likelihood Confidence Intervals
Specifies the type of confidence intervals that are shown in the Parameter Estimates table. When this option is selected, a profile likelihood confidence interval appears. Otherwise, a Wald interval appears. In the report, the interval type is noted below the Parameter Estimates table. This option is on by default when the computational time for the profile likelihood confidence intervals is not large.
Note: You can change the α level for the confidence intervals by selecting Set Alpha Level from the red triangle menu in the Fit Model launch window. The default α level is 0.05.
Hazard Ratios
Shows or hides the hazard ratios for the effects. For continuous columns, unit hazard ratios and range hazard ratios are calculated. The Unit Hazard Ratio is Exp(estimate) and the Range Hazard Ratio is Exp[estimate*(xMax – xMin)]. The Unit Hazard Ratio shows the risk change over one unit of the regressor, and the Range Hazard Ratio shows the change over the whole range of the regressor. For categorical columns, hazard ratios are shown in separate reports for each effect. Note that for a categorical variable with k levels, only k -1 design variables, or levels, are used.
Tip: To see Reciprocal values in the Hazard Ratio report, right-click in the report and select Columns > Reciprocal.
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
Effect Summary
Shows or hides the Effect Summary report, which enables you to interactively update the effects in the model. See “Effect Summary Report” in Fitting Linear Models.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
