Publication date: 01/13/2026
Google Sheet Settings
Change the following settings, if necessary, and then click Import to import the sheet data.
Sheet contains column headers
Select if the worksheet contains rows with column headers.
Column headers start on row
Indicates which row the column headers begin on in the worksheet. Click the up arrow Image shown here until the headers begin on the correct row, or enter the row number and press Enter.
Data starts on row
Indicates which row the data start on in the worksheet.
Select Sheets to Open
Deselect any sheets that you do not want to import by pressing Ctrl and clicking a sheet.
Advanced Options
Cell Range
Imports cells within the specified range (for example, G5:G17).Import cell colors
Applies the cell coloring from the worksheet to the data table.
Suppress empty columns
Prevents empty columns from appearing in the data table.
