Essential Graphing > Graph Builder > Graph Builder Options
Publication date: 01/13/2026
The Graph Builder red triangle contains these options:
Show Control Panel
Shows or hides the platform buttons, the Select Columns box, and the drop zone borders.
Show
Title
Shows or hides the graph title. Right-click the title to change the alignment or the span of the title.
Subtitle
Shows or hides the graph subtitle. Right-click the subtitle to change the alignment or the span of the subtitle.
Legend
Shows or hides the legend.
Footer
Shows or hides the footer, which contains informative messages such as missing map shapes, error bar notes, frequency notes, and WHERE clauses.
X Axis
Shows or hides the X axis.
Y Axis
Shows or hides the Y axis.
X Axis Title
Shows or hides the X-axis title.
Y Axis Title
Shows or hides the Y-axis title.
Legend Position
Sets the position of the legend. The legend appears on the right side of the graph by default. Putting the legend at the bottom of the graph places it in the center below the graph. The legend items then appear horizontally instead of vertically. Or, you can put the legend inside the graph, on the left or right side.
Legend Settings
Opens a window where you can modify legend settings, such as the title, font, and title position.
Color Settings
Contains the following options:
Continuous Color Theme
Selects the color theme for continuous variables.
Categorical Color Theme
Selects the color theme for categorical variables.
Note: For more information about color themes, see “Create Color Themes in Graphs” in Using JMP.
Lighten large fills
Automatically lightens colors for elements that fill large areas, such as pie, treemap, and mosaic plots.
Use row colors for levels
When every level has a unique color, initialize legend levels with row colors.
Lock Scales
Prevents axis scales and gradient legend scales from automatically adjusting in response to data or filtering changes.
Error Bar Offset
Adjust the offset for overlaid error bars.
Parallel Y Axes
All Y axes share the same graph. This option is similar to parallel coordinates but supports X variables.
Link Page Axes
Links or unlinks graph axis scales across levels of the By group variable in the Page zone.
Fit to Window
Specifies whether the graph is resized as you resize the JMP window. The default setting is Auto, which is usually set to On except when the window is shared with other content or if there is a Page variable. To always fit the graph inside the window, keep the setting at On. You can also maintain the aspect ratio. To prevent the graph from resizing, change the setting to Off.
Sampling
Uses a random sample of the data to speed up graph drawing. You can enter a proportion of the sampling rate or a fixed sample size. If the sample size is zero or greater than or equal to the number of rows in the data table, then sampling is turned off. This option enables you to use a subset of the data during graph setup as an aid for visualization.
Graph Spacing
Sets the amount of space between graph panels.
Include Missing Categories
Enables a graph to collect and display missing values for categorical variables.
Set Alpha Level
Enables you to set the Alpha level for graphs and statistics that use an alpha value for confidence intervals.
Launch Analysis
Launches the Fit Model platform with the variables on the graph placed into roles. It launches the Distribution platform when only one variable is placed.
Make into Data Table
Creates a new data table that contains the results from the graph.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
