Using JMP > JMP Reports > Group Platform > Group Platform Options
Publication date: 01/13/2026
The Group Platform red triangle contains all of the menu options of the individual platforms and enables you to automatically broadcast options to the platforms in the group. The Group Platform contains the following options:
Layout
Enables you to display the platforms vertically, horizontally, in rows, or in tabs.
Hide Empty Platforms
Enables you to hide the platforms that were unable to compute.
Auto Broadcast
Enables you to automatically broadcast to all levels of the interactive actions in reports.
Order By
Sorts the levels of platforms by platform-computed metrics. For example, goodness of fit in a Fit platform or column statistics, in ascending or descending order.
Local Data Filter
Shows or hides the local data filter that enables you to filter the data that is used in a specific report.
Redo
Platform Preferences
Save Script
