Publication date: 01/13/2026
Hide Columns in Data Tables
When your data table contains columns that you do not want to see in the data grid, you can hide those columns. Note the following tips:
• Hidden columns appear in launch windows and are available for analyses.
• A mask icon Image shown here appears to the right side of the column name in the Columns panel.
To hide columns
1. Select one or more columns that you want to hide.
2. Perform one of the following tasks:
– Right-click the highlighted column name in the Columns panel and select Hide/Unhide.
– From the Cols menu, select Hide/Unhide.
To unhide columns
1. Select the columns in the Columns panel.
