Using JMP > Enter and Edit Your Data > Assign Characteristics to Rows and Columns > How to Find Options for Rows and Columns
Publication date: 01/13/2026
You can access the menu for row actions from the following places:
• The Rows menu in the menu bar
• Right-click a row
• The Rows panel red triangle
• The red triangle in the lower triangular area of the data grid above the row numbers
Similarly, you can access the menu for columns actions from the following places:
• The Cols menu in the menu bar
• Right-click a column
• The Columns panel red triangle
• The red triangle in the upper triangular area of the data grid above the row numbers
