Using JMP > Import Your Data > Import SPSS Files
Publication date: 01/13/2026
Import SPSS Files
JMP opens SPSS files as data tables and maintains several SPSS features:
• General numeric and character data with minimal formatting are supported.
• SPSS date, datetime, and time formats are supported.
• By default, labels are converted to column headers. When you select this option, and the data contains no labels, the columns are named Column 1, Column 2, and so on.
You also have the option of selecting the conversion method for column headers when opening an SPSS file. The method that you select then overrides the preferences.
To change the default conversion method, select File > Preferences (or JMP > Preferences on Apple macOS). On the Third Party Data page, deselect Use SPSS labels for column names during import. Variable names are then imported automatically as column headers.
• The value labels that you defined in the SPSS file are saved as Value Labels column properties. The value label then appears in each data table cell instead of the original value. For more information about Value Label properties, see “SPSS Label, Long Name, and SAS Label”.
• SPSS can assign certain values in a variable to be treated as missing for analyses. For example, the value 64 could be regarded as missing for a Height variable. Then, the calculation of the distribution of height would ignore values of 64. When you import SPSS, these values are included in the Missing Value Codes column property for the appropriate variable.
Missing value ranges of up to 20 numbers are supported. If the range begins with a negative number, the numbers count down to the maximum value (for example, -10 through -5). If the range begins with a positive number, the numbers count up from the minimum value (for example, 1 through 12).
Custom currency formats selected in an SPSS file are not maintained on import. In addition, JMP does not read SPSS data that contains double-byte characters, such as non-Unicode Japanese characters.
To open an SPSS file (Windows)
1. Select File > Open.
2. From the list next to File name, select SPSS Data Files (*.sav).
3. Select the SPSS file.
4. (Optional) To specify the column headers, select one of the following Set JMP column names from options:
– SPSS Labels creates column headers from SPSS labels.
– SPSS Variable Names creates column headers from variable names.
5. Click Open.
JMP opens the file as a data table.
To open an SPSS file (Apple macOS)
2. Select the SPSS file.
3. (Optional) To specify the column headers, choose one of the following options:
– Deselect Use SPSS Labels as Headings to convert variable names to column headers.
– Select Use SPSS Labels as Headings to convert labels to column headers.
4. Click Open.
Notes:
• As with importing other files, you might experience a delay when opening and saving large SPSS files.
• A pipe (|) now separates words within a multiple response in the .sav file’s SPSS label (as in “detergent|liquid”). To change the delimiter, run the following JSL script, where the colon is the new delimiter:
Preference(SPSSMultiResponseDelimiter(":"))
