Apple macOS Menu Descriptions
Publication date: 01/13/2026
JMP Menu
Item
Description
About JMP Pro...
Shows the product version, registration, user and system information, the JMP web page link, and more. (Pro is displayed in the menu item when you are using JMP Pro.)
U.S. Government Notice
Shows the U.S. Government restricted rights notice.
Settings...
Enables you to edit settings for start-up items, reports, tables, analysis platforms, import and export settings, graphic formats, fonts, and more. Also enables you to restore the defaults.
Services
Shows available Apple macOS services.
Hide JMP
Removes the JMP application from view.
Hide Others
Removes all other applications from view, leaving only JMP visible.
Show All
Brings all open applications into view.
Quit JMP
Closes all JMP windows and quits JMP. Prompts you to save new or changed JMP files. Also asks whether you want to save the session script.
File Menu
Item
Description
New
Creates a new data table, JSL script, JMP notebook, Python script, SAS program, journal, database query, project, application, dashboard, add-in, or workflow.
Open...
Locates and opens files of different types.
Open Recent
Lists the most recently opened files. The Clear Menu command at the bottom of the list enables you to clear the list.
Open Multiple...
Opens multiple files from a folder, combining similar files into data tables.
Connect To
Enables you to set up connections to data connectors, ODBC drivers, and servers.
Close
Closes the active window. Prompts you to save changes.
Close Multiple...
Enables you to choose which open windows to close. Prompts you to review the modified documents.
Save
Writes the active window to a file with the appropriate extension. Press Ctrl and select Save Selection As to save the highlighted portion of an analysis window in a graphic format. Press Ctrl and Option and then select Save All to save the content in all open JMP windows.
Save As...
Writes the active window to a file after prompting you for a file name and folder.
Revert to Saved
Restores the current JMP file to its last saved condition.
Close Project
Closes the current project. Available only when a project is open.
Save Project
Saves the current project. Available only when a project is not saved.
Save Project As...
Saves the current project using the specified name. Available only when a project is open.
Export...
Exports data to text, JSON data, Microsoft Excel, Google Sheets, SAS data set, or SAS Transport file formats. Exports reports into text, images, HTML, interactive HTML with dynamic graphics, RTF, and Microsoft PowerPoint formats. Exports a JMP application source file as an application that runs when opened in JMP or exports the JMP application as a JSL file. The available options are based on the type of file that you are exporting.
Publish...
Publishes the current reports to a web page. You can publish to JMP Live, JMP Public, or to an interactive HTML web report. You can also publish data to JMP Live. Use the Manage Connections option to add new JMP Live connections.
Internet Open...
Opens remote files in a browser or text editor window and opens an HTML table as a data table. Enables you to open JMP data tables and run scripts from a URL. Also provides a way to open data as a Google Sheets spreadsheet.
Page Setup...
Displays the standard window for setting printed page properties.
Print...
Prints the active window.
Save Session Script...
Creates a JMP Scripting Language (JSL) script to re-open all currently open files and re-run all currently open analyses and graphs.
Edit Menu
Item
Description
Undo
Cancels the effect of the most recent reversible Edit, Rows, or Columns command.
Redo
Reverses the most recent Undo command.
Cut
Copies selected data table cells to the clipboard and replaces the data with missing values. In reports and other windows, copies selected content to the clipboard.
Copy
Copies selected data table cells to the clipboard. In reports and other windows, copies selected content to the clipboard.
Copy With Column Names
Copies selected data table cells and column names to the clipboard.
Copy As Text
Copies all text (but no graphs), or text selected by using the selection tool, from the active report window to the clipboard.
Paste
Copies content from the clipboard into the open window.
Paste With Column Names
Copies data from the clipboard into the active data table. Converts text on the first line of the clipboard to column names.
Delete
Removes selected data table cell contents and adds missing values. In journal and script windows, removes selected content.
Select All
Selects all rows in a data table. In reports and other windows, selects all content when one item is selected.
Search
Finds and replaces text in data tables and scripts.
Reformat Script
Adds tab and return characters where appropriate to display the script in a more readable layout.
Go To Line...
Scrolls to a specific line number in a script.
Balance
Selects all text within a pair of brackets that include the cursor. Available only if a script window is active.
Comment Block
Comments the selected block in the JSL script.
Uncomment Block
Uncomments the selected commented block in the JSL script.
Shift Right
Shifts selected lines in a script to the right.
Shift Left
Shifts selected lines in a script to the left.
Insert Snippet
Enables you to add snippets in the JSL script.
Encrypt Script...
Places encoding in a script so that you must have the password to open or run the script. Available only if an unencrypted script is in the active window. When an encrypted script is in the active window, the menu item changes to Decrypt Script.
Decrypt Script...
Enables you to open or run an encrypted script. Available only if an encrypted script is in the active window.
Import as Data
Imports text-formatted data by using the Import Settings in JMP > Preferences > Text Data Files. Before selecting the Import as Data command, you must paste the data into the active script window.
Run Script
Processes JSL commands that are entered in the script window. You are prompted to select a data table if none are opened. If several data tables are opened, the script is run on the last table that you opened. Otherwise, the script is run on the only open data table. When a script is being run, this option changes to Stop Script.
Stop Script
Stops running the JSL script. When a script is not running, this option changes to Run Script.
Debug Script
Enables you to troubleshoot script errors in the JSL Debugger.
Capture to Notebook
Enables you to create a notebook in which you can create, document, organize, and test scripts.
AutoFill
Enables you to autopopulate either contacts or passwords.
Journal
Copies output from a data table or report window to a journal window. Enables you to save reports, add notes, and organize output.
Lock Journal
Prevents you from editing the journal. The command changes to Unlock Journal when the journal is already locked.
Start Dictation...
Allows you to dictate text anywhere that you can type it.
Emoji & Symbols
Allows you to enter emoji, symbols, accented letters, and characters from other languages.
Tables Menu
Item
Description
Summary
Creates a table that contains user-specified summary statistics that are calculated from the active data table.
Subset
Creates a new data table that is a subset of the active data table and can be linked to the original data table.
Sort
Sorts a JMP data table by one or more columns. This creates a new data table, or you can replace the original table with the sorted table.
Stack
Stacks selected columns into one or more new columns in a new data table.
Split
Splits one or more columns, according to values in a Split By column, to form multiple columns in a new data table.
Transpose
Creates a new data table in which the data in the selected columns of the original table are arranged in rows. Transposing equates to switching the rows and columns in the original selection.
Join
Adds columns from a second table to the main table, using row number or matching columns, or by forming a Cartesian join.
Update
Replaces data in the active table with data from a second table without producing a new table.
Concatenate
Stacks two or more tables on top of each other by matching column names.
JMP Query Builder
Interactively queries one or more data tables to create a new data table.
Missing Data Pattern
Describes the missing data in your table in terms of the columns where it is missing.
Compare Data Tables
Compares the numbers of columns and rows, table properties and scripts, column attributes and properties, and data in two open data tables.
Anonymize
Removes unique identifiers from the data table or selected columns.
Rows Menu
Item
Description
Hide and Exclude
Hides and excludes selected rows in plots and analyses.
Exclude/Unexclude
Excludes or includes selected rows in analyses.
Hide/Unhide
Hides or shows selected points in all plots.
Label/Unlabel
Labels or unlabels selected points in all plots.
Colors
Changes selected points in all plots to a specified color.
Markers
Replaces selected points in all plots with symbols that you select.
Next Selected
Locates and flashes the first selected row in a data table after the current row.
Previous Selected
Locates and flashes the first selected row in a data table before the current row.
Row Selection
Provides several options for selecting rows based on one or more conditions.
Clear Row States
Clears all active row states in the data table.
Clear Selected Row States
Clears all selected row states in the data table.
Color or Mark by Column...
Assigns colors or markers to rows based on values in a selected column.
Row Editor
Opens a window that enables you to edit cells in a row. Helps you select rows and create new rows.
Delete Rows
Removes all selected rows from the data table.
Add Rows...
Adds rows to a specified location in the data table.
Move Rows...
Moves selected rows to a specified location in the data table.
Data Filter
Selects, shows, or includes rows based on conditions on the values of selected columns.
Cols Menu
Item
Description
New Columns...
Adds a new column, and enables you to name the column and change attributes and properties.
Column Selection
Highlights and scrolls to the selected column. Locates and flashes the first or next selected column in a data table after the current column. Selects any column that is currently deselected and deselects any column that is currently selected.
Reorder Columns
Moves the selected column to the specified location. Rearranges columns by the original order, name, data type, modeling type, or in reverse order.
Column Info...
Shows the column properties and enables you to change the column name, attributes, and properties for the selected column or columns.
Columns Manager
Shows the column properties and statistics.
Standardize Attributes...
Sets attributes and properties for multiple columns at once.
Preselect Role
Assigns an analysis role, which can be saved with the data table, to the selected column or columns.
Formula...
Shows the formula editor window for the selected column or columns.
Label/Unlabel
Tells JMP whether to use values from the selected column or columns to identify points in plots when the cursor is placed near them. To display labels for points on plots, the corresponding rows must have a label row state.
Scroll Lock/Unlock
Locks or unlocks selected columns into or from the left-most position in the table. Locking a column keeps its contents visible when you scroll horizontally.
Hide/Unhide
Hides or shows selected columns without removing them from the table. Retains them in analyses.
Exclude/Unexclude
Excludes or includes selected columns in analyses.
Use for Marker
Displays the images in expression columns as markers on graphs.
Recode...
Enables you to edit and group cell values for the selected column.
Utilities
Restructures data. Compresses columns, converts a column of delimited data to multiple columns, creates indicator columns, combines columns, customizes binned data, converts a numeric column of codes to value labels, converts a column of strings to numeric codes, and recodes column names. New Column by Text Matching uses a regular expression to parse a column of text.
Column Names
Move Up moves the first row of data to the column heading row. Move Up and Append appends the first row of data to the column names. Move Down moves the column headings to the first row of data. Recode Names opens a recode window that provides recode options for column names.
Clear Cell Colors
Clears the color of selected colored data table cells.
Reset Display Width
Resizes the selected column to fit the width of the longest cell entry.
Group Columns
Groups columns under one heading to manage large numbers of columns and facilitate analysis role assignment. Grouped columns are shown in outline view under a gray disclosure icon in the columns panel.
Ungroup Columns
Removes the grouping heading and displays individual column names in the column panel and analyses.
Expand All Column Groups
Expands all grouped columns in the Columns panel.
Collapse All Column Groups
Collapses all grouped columns in the Columns panel.
Delete Columns
Removes selected columns from the data table.
DOE Menu
Item
Description
Custom Design
Creates D-optimal and I-optimal designs for a wide range of design situations and constraints.
Augment Design
Adds runs to an existing design in an optimal fashion. Provides different choices for how to add these runs.
Easy DOE
Provides a platform for designing, running, saving, analyzing, predicting, and documenting the results of a designed experiment.
Definitive Screening
• Definitive Screening Design creates a design with three levels for every quantitative factor. Main effects are independent of two-factor interactions, and two-factor interactions are not confounded with each other.
• Fit Definitive Screening provides options for modeling definitive screening designs.
Classical
• Screening Design constructs classical and main effects screening designs. The factors can be 2-level continuous, discrete numeric, and categorical factors with an arbitrary number of levels.
• Fit Two Level Screening provides options for modeling screening designs.
• Response Surface Design generates a list of classical response surface designs for the specified number of continuous factors and creates the chosen design.
• Full Factorial Design creates a design that uses all combinations of factor levels for a set of continuous and categorical factors with an arbitrary number of levels.
• Mixture Design creates a design that is appropriate when the factors are components in a mixture. Some design types accommodate linear constraints.
• Taguchi Arrays constructs a Taguchi design. Signal and noise factors, a choice of inner and outer array designs, and signal-to-noise ratios are supported.
Design Diagnostics
• Evaluate Designs evaluates designs for any table that is treated as a design. You can modify the model terms and the aliasing terms, and the diagnostics update accordingly.
• Compare Designs compares two or three designs simultaneously to explore and evaluate their performance. Provides diagnostics that show how the designs perform relative to each other as well as how they perform in an absolute sense.
Consumer Studies
• Choice Design creates an optimal discrete choice conjoint experimental design. These designs are useful in studies where users are asked to specify preferences relative to combinations of product or service features.
• MaxDiff Design constructs a design that consists of choice sets that can be presented to respondents as part of a study where respondents specify most and least preferred combinations of features.
Special Purpose
• Covering Array creates a design for testing systems where failures occur as a result of interactions among components or subsystems (JMP Pro).
• Space Filling Design creates a design that is appropriate when modeling deterministic or nearly deterministic systems, such as computer simulations.
• Constant Stress ALT Design creates an accelerated life test plan with one or more accelerating factors.
• Nonlinear Design creates an optimal design for estimating the parameters of a nonlinear model.
• Balanced Incomplete Block Design creates a design for testing a treatments in b blocks where only k treatments (k < a) can be run in any one block.
• MSA Design generates a full factorial design for a measurement systems analysis (MSA) experiment and provides design diagnostic measures.
• Group Orthogonal Supersaturated Design creates a supersaturated design where the factors are partitioned into k orthogonal groups, with k = 2 or a multiple of 4.
• Fit Group Orthogonal Supersaturated provides options for modeling a group orthogonal supersaturated design.
• Accelerated Life Test Design constructs tests based on one or two accelerating factors with either a main effects model or an interaction model for the latter.
Sample Size Explorers
Enables you to investigate the impact of sample size on your ability to answer specific questions when planning experiments or studies.
Analyze Menu
Item
Description
Distribution
Provides a histogram for continuous data and a bar chart for nominal or ordinal data, along with relevant summary statistics. Presents options for many one-sample analyses, based on modeling type.
Fit Y by X
Shows plots that describe the relationship between any two variables. Provides two-sample analyses based on the modeling types of the two variables, such as bivariate, one way, logistic, and contingency analysis.
Tabulate
Constructs tables of descriptive statistics by using an interactive interface.
Text Explorer
Analyzes pieces of unstructured text, such as comment fields in surveys or incident reports, enabling you to interact with the text data with tools to consolidate similar terms, recode misspecified terms, and gain an understanding of the underlying patterns in your textual data. (Analytics are available in JMP Pro.)
Fit Model
Fits models that involve one or more Y variables and multiple X variables. Techniques include standard least squares, stepwise, generalized regression (JMP Pro), mixed models (JMP Pro), generalized linear mixed models (JMP Pro), MANOVA, loglinear variance, logistic, proportional hazards, parametric survival, generalized linear models, partial least squares (JMP Pro), response screening, and causal treatment models.
Predictive Modeling
Offers predictive modeling techniques: neural, partition analysis, bootstrap forest (JMP Pro), boosted tree (JMP Pro), K-nearest neighbors (JMP Pro), Naive Bayes (JMP Pro), support vector machines (JMP Pro), model screening (JMP Pro), and model comparison (JMP Pro). The menu also provides options to make validation columns and access prediction models that you saved in the Formula Depot (JMP Pro).
Specialized Modeling
Offers specialized modeling techniques: nonlinear, functional data exploration, Gaussian process, Bayesian optimization, time series, time series forecast, and matched pairs.
Screening
Offers techniques for screening large data sets, including analyzing outliers and missing values.
• Explore Outliers enables you to explore outliers in both the univariate and multivariate cases.
• Explore Missing Values enables you to explore and impute missing values in your data.
• Explore Patterns enables you to explore and find unusual features or patterns in your data.
• Response Screening automates the process of conducting tests across a large number of responses.
• Predictor Screening is useful in screening a data set for significant predictors.
• Association Analysis analyzes transaction (market basket) data to identify items that appear together in transactions (JMP Pro).
• Process History Explorer analyzes complex processes to identify where a defect has occurred.
Multivariate Methods
Offers techniques for exploring relationships among multiple variables: multivariate fitting, principal components, discriminant analysis, partial least squares, multiple correspondence analysis, structural equation models (JMP Pro), factor analysis, multidimensional scaling, multivariate embedding, and item analysis.
Clustering
Offers techniques for clustering: hierarchical clustering, K-means clustering, normal mixture clustering, clustering rows based on categorical variables by using multinomial mixtures (latent class analysis), and clustering variables into groups of highly correlated variables.
Quality and Process
Offers techniques for evaluating quality-related issues in processes or products: control charts (including an interactive control chart builder), CUSUM control charts, EWMA control charts, model-driven multivariate control charts, legacy control charts, process screening, process capability analysis (including capability for non-normal process measurements), measurement systems analysis, variability and attribute gauge charts, Pareto plots, and fishbone (Ishikawa Cause and Effect) diagrams. Other options include managing specification limits and creating a graph of Operating Characteristic Curves (OC Curves).
Reliability and Survival
Offers techniques for fitting survival and reliability data: life distribution, reliability forecasting, fit life by x, parametric survival distributions, cumulative damage, fatigue analysis, repeated measures degradation, destructive degradation, recurrence analysis, reliability growth, reliability block diagrams (JMP Pro), repairable systems simulation (JMP Pro), product-limit survival fit, degradation, and proportional hazards modeling.
Consumer Research
Offers techniques for studying consumer preferences. Options include categorical response survey analysis, choice models, MaxDiff analysis, uplift models for identifying the positive effects of marketing actions (JMP Pro), and multiple factor analysis.
Life Sciences
• Marker Statistics platform provides a way to explore several properties of all biallelic markers in a data set, for the purpose of quality control (QC) and potentially identifying markers to exclude from the analysis.
• Marker Simulation platform evaluates potential crosses by using information from parental genetic markers and predictor formulas for traits of interest to breeders. It generates output of the simulated marker genotypes for all progenies with their respective predicted trait values across generations. It also provides summary statistics for the predicted trait values for each cross across generations.
• Marker Relatedness platform assesses different measures of genetic relatedness between pairs of individuals based on their genetic markers. The output of the platform is a genomic relationship matrix that can be used to fit GBLUP models under the Fit Model platform with the Response Screening personality. The relationship matrix can also be used to assess groups of related individuals by using principal component analysis and clustering.
• Marker Admixture platform estimates probabilities of ancestral origins (admixture probabilities) for individuals based on a series of marker genotypes.
• Marker Imputation platform imputes numeric missing marker genotypes (0, 1, or 2) for diploid or polyploid organisms by using the K-Nearest Neighbor imputation or other methods. Distances between markers and between samples are computed. The closest samples and markers to each missing genotype are then used to impute the missing genotypes.
• Normalization platform provides different processes for normalizing your data. Numerous factors can affect the absolute values of the raw data that is generated in any experiment. Before data can be analyzed and assessed, it is usually necessary to normalize experimental results against some standard. The methods include Row Standardization, Counts/Reads per Million, Reads/Fragments per Kilo Bases or Transcripts per Million Mapped Reads/Fragments, Centered Log Ratio, Wrench, and Variance Stabilization/Dispersion.
• Distance Matrix platform computes various measures of distance or dissimilarity between the observations (rows) of a data set. The methods include Euclidian (default), Jaccard, Bray-Curtis, Gower, Hamming, Binary, and Manhattan distance.
Graph Menu
Item
Description
Graph Builder
Provides an interactive interface to create flexible trellis displays that are useful for visualizing multivariate data. Plots can be conditioned on discrete and continuous variables and include dot plots, smooth curves, normal density ellipses, box plots, lines, bar charts, and histograms. Available plots include contour plots, maps, parallel plots, mosaic plots, pie charts, treemaps, area charts, heat maps, formula charts, and line of fit. Map shapes are also supported.
Bubble Plot
Displays circles according to positional specification. Circles can be sized and colored according to selected variables. When there is a time variable, selected variables can be viewed dynamically over time.
Scatterplot Matrix
Displays scatterplots and density ellipses for all pairs of Y variables or for a selection of Y variables plotted against one or more X variables.
Parallel Plot
Draws a plot that connects the values of selected Y variables for each row in the data table.
Cell Plot
Creates a rectangular array of cells that are drawn with a one-to-one correspondence to data table values and colored by the values in the cells.
Scatterplot 3D
Creates three-dimensional rotatable plots for multiple Y variables. Displays and saves principal components, standardized principal components, and rotated components. Also displays normal contour ellipsoids, nonparametric density contours, and biplot rays.
Contour Plot
Constructs contour plots for one or more numeric response variables, Y, across a grid that is defined by two numeric X variables.
Ternary Plot
Illustrates the distribution of three-part (numeric) compositional data, using a two-dimensional plot.
Surface Plot
Creates a three-dimensional, rotatable display of points or of a surface that is defined by a saved formula.
Profiler
Displays prediction traces for each X variable, based on saved prediction formulas for each numeric response and linear constraints on the X variables. Allows simultaneous optimization of responses by using desirability functions, estimation of response distributions by using the simulator, and accesses and links to other profilers. Can be saved as an Adobe Flash file (.swf) to display in a web browser.
Contour Profiler
Displays contours of the prediction formulas for two factors at a time, along with three-dimensional mesh plots. Accesses the simulator and links to other profilers.
Mixture Profiler
Displays a ternary plot and contours of the prediction formula for models that involve mixture factors. Accesses the simulator and links to other profilers.
Custom Profiler
Provides an interface for simultaneous optimization of responses, similar in function to the profiler. Allows linear constraints and a user-defined criterion for optimization and displays predicted performance relative to benchmarks. Accesses the simulator and links to other profilers.
Tools Menu
Item
Description
Arrow
The default tool.
• Enables you to select points in plots and analysis options. Drag the cursor to select multiple points.
• Rotates the plot in Surface Plot and Scatterplot 3D.
Help
Opens context-sensitive help when you click the help tool in any part of a display or report.
Selection
Enables you to select rows or regions of rows when you click and drag. Selects portions of graphical output or analysis results.
Grabber
• Changes axis scaling when you hover with the grabber and click over an axis. The hand changes orientation to indicate the direction of change.
• Changes both axes simultaneously when you click and drag within a plot.
• In histograms, changes the number of bars or shifts the boundaries of the bars on the axis when you click and drag.
• In any report table, rearranges columns.
• In Surface Plot and Scatterplot 3D, click and drag an axis to move it. When you click the plot, the grabber turns to an arrow and enables you to rotate the plot.
Brush
Enables you to select one or more points when you brush over them.
Lasso
Enables you to circle points with a curve. Press Shift or Ctrl and circle more points to extend a selection.
Magnifier
Enables you to zoom in to a plot when you click where the enlarged graph should be centered. Double-click to restore the graph to its original dimensions.
Crosshairs
Displays a movable set of magnified axes to precisely locate points and estimate distances on plots.
Ruler
Enables you to drag a ruler on a graph to measure distances.
Annotate
Enables you to add editable text notes to JMP reports and journals.
Line, Polygon, and Simple Shape
Enables you to draw lines, polygons, and shapes on JMP reports and journals. Right-click a line or shape for a menu of options.
The Project menu appears only when a project is open.
Project Menu
Item
Description
Undo Layout
Enables you to undo actions performed on the tabs.
Redo Layout
Enables you to reverse actions performed on the tabs.
Reset Layout
Returns all open reports and data tables to a tabbed view.
Show Workspace
Opens or closes the Workspace pane in the project window. This pane shows tables, reports, and scripts that are open in the project.
Show Bookmarks
Opens or closes the Bookmarks pane in the project window. This pane shows shortcuts to frequently used files and folders, organized into groups.
Show Contents
Opens or closes the Contents pane in the project window. This pane enables you to view, open, and modify files in the project contents.
Show Recent Files
Shows a list of recently used files, which are the same files that are shown on the Home Window.
Show Log
Opens or closes the Log in the project window.
Project Settings
Enables you to write a script to automate tasks when the project is opened.
View Menu
Item
Description
New Data View
Displays a duplicate view of the active data table that is linked to the original data table.
Redraw Window
Refreshes a window after it shows stray imperfections from high-speed, dynamic handling.
Show Properties
Enables you to modify the formatting of display boxes in a report.
Make Text Bigger
Increases the size of text in all open windows.
Make Text Smaller
Decreases the size of text in all open windows.
Show Toolbar
Shows toolbars. (Available only when toolbars are hidden.)
Hide Toolbar
Hides toolbars. (Available only when toolbars are shown.)
Customize Toolbar
Enables you to drag new toolbars, platform icons, and miscellaneous icons to the toolbar and change their display size. Also enables you to display these items as icons, text, or both and revert to the original toolbars.
Customize Menus
Displays the JMP Menu Editor for customizing menu items.
Running Queries
Enables you to view ODBC queries that are running against a SQL database.
Add-Ins...
Lists the add-ins that you installed in JMP.
Window Menu
Item
Description
Minimize
Minimizes the active window. Press Option and select Minimize All to minimize all open JMP windows.
Zoom
Optimally sizes a window for your display. Press Option and select Zoom All to resize all open JMP windows.
Move Window to Left Side of Screen
Moves the active JMP window to the left side of the screen. This command is available before you select either of the Move Window commands or after you select Move Window to Right Side of Screen.
Moves the active JMP window to the right side of the screen. This command is available before you select either of the Move Window commands or after you select Move Window to Left Side of Screen.
Revert
Appears after you select Move Window to Left Side of Screen or Move Window to Right Side of Screen.
Hide
Suppresses the display of the active window but does not close the window.
Hidden
Enables you to select the hidden windows that you want to view.
Set Report Title
Enables you to rename the active report.
JMP Starter
Opens or brings the JMP Starter window to the front.
Log
Opens a window that shows information such as JSL statements as they run and script errors.
JMP Home
Opens or brings to front a window that lists recently opened JMP files. Shows open JMP windows in an outline view (the same list that appears when you select File > Open Recent).
Show Data Table
Brings the data table for the open report to the front.
Combine Windows...
Enables you to select open JMP windows and merge them into a dashboard. Options include using a report as a selection data filter and displaying in Full or Summary view.
Move to/from Project...
Enables you to move selected windows to or from a new or open project.
Bring All To Front
Brings all JMP windows to the front. Press Option and select Arrange in Front to display the windows one in front of another.
Recall Last Platform
Opens the platform launch window that was last opened.
Help Menu
Item
Description
Ask JMP Learnbot
Allows you to ask the AI-powered learning assistant questions about JMP. Available only if you install the JMP LearnBot add-in.
Search JMP
Enables you to search JMP to find statistical tests and other capabilities.
JMP Online Help
Opens the latest JMP Help in a web browser.
Help Tool
Allows you to click on any part of a report to get help.
Quick Start
Opens the Quick Start window, which provides tips to help you quickly learn the basics of JMP.
Documentation PDFs
Provides links to all JMP documentation PDF files. Available only if you install the documentation add-in.
JMP Capabilities
Opens the JMP website where you can learn what JMP can do for you.
Learn JMP
Opens the JMP website where you can learn JMP through short videos and resources.
JMP User Community
Opens the JMP website where you can connect with others to learn, solve problems, and share ideas.
JMP Marketplace
Opens the JMP website where you can discover extensions to enhance JMP.
New in JMP
Opens the JMP website where you can learn about the new features in the latest JMP release.
Sample Data Folder
Opens a list of JMP sample data to learn about JMP analyses. Open a sample data file and run a script to see a sample analysis.
Sample Index
Opens the Sample Index window, which provides links to sample files. Many sample data tables include scripts that you can run to see examples of JMP tools and analyses. You can also run the sample scripts themselves to see examples of JMP tools and analyses.
Scripting Index
Defines JSL functions, JSL objects, and display box elements. Several search options are available. You can also run examples and read online Help for the components. Above the list of commands, select All Categories to search all functions, objects, and display box elements.
My JMP
Opens my.jmp.com on the web.
Deauthorize...
Allows you to remove your JMP authorization from the current machine.
The Format menu appears only when an application or dashboard is open.
Format Menu
Item
Description
Add Module
Creates a new empty module.
Delete Module
Removes the currently displayed module from the application or dashboard.
Align Boxes
Lines up the selected objects by the type of alignment that you select from the submenu.
Add Container
Places the selected object inside the object that you select from the submenu.
Remove Container
Removes the selected object from its container.
