Welcome to JMP > Learn about JMP > JMP Help Menu
Publication date: 01/13/2026
JMP Help Menu
Starting at JMP 18, the JMP Help menu has been updated.
Menu Item
Description
Search JMP
Lets you search JMP for statistical tests and other capabilities. For more information, see Search JMP.
JMP Online Help
Opens the latest version of the Help in a web browser.
Help Tool
Lets you click on any part of a data table or report window to get help.
Quick Start
Formerly referred to as Tip of the Day, the Quick Start provides you with tips to help you quickly learn the basics of JMP. For more information, see Get Started with JMP.
Documentation PDFs
When installed, it provides local access to the JMP documentation PDF files. For more information, see Documentation PDF Add-in.
Note: This menu option appears only if you have downloaded and installed the documentation add-in.
JMP Capabilities
Opens a web browser that lists the tools and features that are available in JMP. It also provides links to the online Help, where more information is available.
Learn JMP
Opens a web browser that takes you to JMP learning materials. You can learn JMP through short videos and other resources.
JMP User Community
Opens a web browser where you can connect with other JMP users to learn more, solve problems, and share ideas for improving JMP. For more information, see JMP User Community.
JMP Marketplace
Lets you discover and download JMP extensions. For more information, see JMP Marketplace.
New in JMP
Opens a web browser where you can learn about the new features in the latest release of JMP.
Sample Data Folder
Lets you access sample data to learn about JMP analyses. You can open a sample data file and run a script to see a sample analysis. For more information, see Sample Data Tables.
Sample Index
Lets you find sample data tables based on analysis type or industry, teaching resources, and links to additional sample material. For more information, see Sample Data Tables.
Scripting Index
Enables you to search for JMP scripting commands and learn how to use them. For more information, see Learn about JSL.
My JMP
Opens https://my.jmp.com on the web.
Deauthorize
Allows you to remove your JMP authorization from the current machine. For more information, see Deauthorize User.
About JMP
Displays your JMP version and lets you check for software updates. This option is available on Windows only.
