Predictive and Specialized Modeling > Make Validation Column > Make Validation Column Platform Options
Publication date: 01/13/2026
Image shown hereMake Validation Column Platform Options
The Make Validation Column red triangle menu contains the following options:
For more information about the following options, see “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP:
Redo
Platform Preferences
Save Script
Note: Additional options for this platform are available through scripting. Select Help > Scripting Index. In the Scripting Index, you can also find examples for scripting the options that are described in this section.
