Publication date: 01/13/2026
Matched Pairs Platform Options
The Matched Pairs red triangle menu contains the following options:
Plot Dif by Mean
Shows or hides the plot of the paired differences by paired means. For a detailed description of this plot, see Difference Plot and Report.
Plot Dif by Row
Shows or hides the plot of paired differences by row number.
Reference Frame
Shows or hides the reference frame on the Plot Dif by Mean plot. A rectangle showing where a plot of Y2 by Y1 would be located inside the plot, tilted and possibly squished. A vertical red line is shown representing the mean of means. The reference frame is shown initially when the range of the differences is greater than half the range of the data.
Dif Statistics
Shows or hides a report of the difference statistics. See Difference Plot and Report.
Plot Percent Dif by Mean
Shows or hides a plot of the paired percent differences by paired means. This plot is equivalent to the Difference plot, but uses the paired differences instead. See Difference Plot and Report.
Plot Percent Dif by Row
Shows or hides a plot of the paired percent differences by row number.
Percent Dif Statistics
Shows or hides a report of the percent difference statistics. This report contains the mean of each response, the percent difference of the means, and a confidence interval for the percent difference. Results of the paired t test are also shown. The percent difference is calculated by dividing the mean difference by the absolute value of the mean of the second variable and multiplying the result by 100.
Wilcoxon Signed Rank
Shows or hides the Wilcoxon signed rank test. The Wilcoxon signed rank test is applied to the paired differences. It is a nonparametric test that compares the sizes of the positive differences to the sizes of the negative differences. The test uses the Pratt method to address zero differences. The test also assumes that the distribution of differences is symmetric. See “Distributions” in Basic Analysis. See also Lehman (2006), Conover (1999, p. 350), and Cureton (1967).
Sign Test
Shows or hides the sign test. This is a nonparametric version of the paired t test that uses only the sign (positive or negative) of the difference for the test.
Bland-Altman Analysis
Shows or hides the Bland-Altman Analysis report. The report contains the bias, or the mean difference in the X and Y variables. The upper and lower limit of agreement are set at bias ± z1-α/2*(standard deviation of the bias).
Bland-Altman Percent Analysis
Shows or hides the Bland-Altman Percent Analysis report. This report is equivalent to the Bland-Altman Analysis report performed on the percent difference.
Equivalence Tests
Launches a window with options for equivalence, superiority, or noninferiority tests for means. This option tests that the means do not differ by more than an amount determined to be practically equivalent. This is the reverse of the usual significance test. See “Equivalence Test Reports” in Basic Analysis.
Set α Level
Changes the alpha level used in the analyses. Affects the confidence intervals in the report and on the plot.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
