Design of Experiments Guide > Mixture Designs
Publication date: 01/13/2026
Mixture Designs
Designs for Formulations
Use the Mixture Design platform to build experiments with factors that are components in a mixture. Choose from several classical mixture design approaches, such as simplex, extreme vertices, and lattice. For the extreme vertices approach, you can supply a set of linear inequality constraints limiting the geometry of the mixture factor space.
In mixture experiments, a factor's value is its proportion of the mixture, which falls between zero and one. Mixture experiments have three or more factors with the sum of the factor proportions equal to one (100%). Mixture experiments differ from other experimental types in that you cannot vary factors independently of one another. When you change the proportion of one factor, the proportion of one or more other factors must also change. This simple fact has a profound effect on every aspect of experimentation with mixtures: the factor space, the design properties, and the interpretation of the results.
Because the mixture components are proportions that sum to one, the feasible region of a mixture design takes the form of a simplex. For example, a three factor deign can be visualized with a triangular two-dimensional graph and a four factor design can be visualized with a three-dimensional tetrahedron.
Figure 14.1 Ternary Plot
Ternary Plot
Contents
Overview of Mixture Designs
Example of a Mixture Design
Build a Mixture Design
Responses
Factors
Ternary Plot Overview
Fit Mixture Designs
Whole Model Tests and Analysis of Variance Reports
Understand Response Surface Reports
Additional Examples of Mixture Designs
Example of an Optimal Mixture Design
Example of a Simplex Lattice Design
Example of an Extreme Vertices Design
Example of an ABCD Design
Example of a Space Filling Mixture Design
Example of a Mixture Design with Analysis
Statistical Details for Mixture Designs
Statistical Details for the Extreme Vertices Method
Statistical Details for FFF Optimality Criterion for Mixture Space Filling Designs
