Using JMP > JMP Preferences > Overview of JMP Preferences
Publication date: 01/13/2026
The Preferences option on the File menu (on the JMP menu on Apple macOS) displays the Preferences window. See Figure 15.1. This chapter describes each category.
On Windows, changes that you make to preferences are stored in a version-specific JMP.PFS file that is located in one of the following folders:
C:\Users\<user name>\AppData\Roaming\JMP\JMP\19\
C:\Users\<user name>\AppData\Roaming\JMP\JMPPro\19\
On Apple macOS, the preferences are stored in com.sas.jmp.plist, which is located in ~/Library/Preferences/.
JMP looks for this file when you open the program and considers your changes to be the factory defaults. All subsequent changes are stored in this file.
To change preferences
1. Select File > Preferences (Windows) or JMP > Preferences (Apple macOS).
The window in Figure 15.1 appears. The previous preferences page that you selected appears.
2. Click a category and make selections.
3. Click Apply to see the results and then click OK.
Notes:
• When you upgrade a subscription product, changes to preferences are maintained. In other JMP versions, you must customize the preferences after each upgrade.
• Your JMP preferences are remembered if you change the JMP display language.
To search preferences
2. In the Filter box at the top of the window, enter your text.
3. (Optional) To filter preferences by the version of JMP that they were added in, click Version and choose minimum and maximum versions.
4. On left side of the window, click a category to see its results.
Matches are highlighted in blue. If you filter by version, the version number appears in a circle.
A search term can show up in these places:
• The preference itself
• A tooltip for the preference
• A list of options for a preference
To reset preferences to the default settings
2. Click Reset All and then click OK.
