Using JMP > Import Your Data > Import PDF Files > PDF Preview Red Triangle Options
Publication date: 01/13/2026
The section describes the red triangle options on the PDF preview pane.
Global Red Triangle
The red triangle in the upper left corner of the PDF preview window contains two options:
Auto-detect tables on this page
Reverts the changes that you made so that the tables are auto-detected again if you previously divided or combined tables.
Ignore tables on this page
Removes the tables from the page. That data is not imported.
Red Triangle on Each Table
Ignore this table
Removes the table. The data is not imported.
Number of rows to use as header
Specifies the number of header rows in the PDF file that are not imported as data.
