Using JMP > JMP Preferences > Preferences for Third Party Data
Publication date: 01/13/2026
These preferences specify settings for third-party data, such as Microsoft Excel and SPSS files.
Figure 15.19 Third Party Data Preferences
Table 15.17 Preferences on the Third Party Data Page
Preference
Description
Excel Open Method
Select one of the options to determine how JMP imports Microsoft Excel worksheets.
Excel Wizard
Lets you preview a Microsoft Excel worksheet and modify the settings before importing the data. This is the default setting on Windows. On Apple macOS, all .xlsx files open in the Excel Wizard.
Open All Sheets
Opens all worksheets in the workbook. On Apple macOS, this preference is for .xls files only.
Select Individual Worksheets
Lets you select the worksheets that you want to open from a workbook. On Apple macOS, this preference is for .xls files only. The option is also provided on Apple macOS when you open a .xls file by using File > Open.
On Windows, you can also select File > Open, select the workbook, click the Open button arrow, and select Open Selected Worksheets or Use Excel Wizard.
Use Excel Labels as Headings
Select this option to allow JMP to use Excel label names as column headers when importing Excel files. Available settings include:
• Use best guess (default)
• Always
• Never
Image Format for PowerPoint
Select the default file format for images that are exported to Microsoft PowerPoint.
Windows does not support the native PDF graphics that are produced on Apple macOS. Apple macOS does not support the native EMF graphics that are produced on Windows. For cross-platform compatibility, specify the PNG or JPEG graphic format. Additional file formats are available through scripting. See “db<<Save Presentation(<path>, <Template(path)>, <Insert("Begin"|"End"|n)|Replace("Begin"|"End"|n)|Append>, <Outline Titles(title location)>, <format>)” in the JSL Syntax Reference.
Use SPSS Labels for column names during import
Select this option to allow JMP to use SPSS label names as column headers when importing SPSS files.
Use Triple-S Labels as Headings
Select this option to allow JMP to use Triple-S label names as column headers.
Automatically generate ODS reports
Select this option automatically generate ODS Output using the SAS Server.
ODS Report Format
Select the format of the ODS report. Available settings are HTML and TEXT. The default setting is HTML.
Import SAS generated datasets into JMP
Select this option to automatically import any SAS code generated data sets into JMP.
Organize Results in a JMP project
Select this option to organize SAS code and results in a JMP project.
ODS Style
Specify the style name for ODS reports. Available settings will depend on the SAS server configuration. The default setting is Statistical.
For more information about the SAS server ODS styles, see the SAS documentation.
Show SAS Log
Select when to show the SAS log. Available settings include:
• Never
• Always
• On Error (default)
Use SAS variable labels for column names during data import
Select this option to use the column labels in the SAS data set as the JMP data table column names when importing a SAS data set into a JMP data table. This option is deselected by default.
Convert SAS custom formats to JMP value labels
Select this option to use the information in the SAS column formats to set JMP value labels when importing a SAS data set into a JMP data table. This option is selected by default.
Warn before closing unsaved imported data
Select this option to trigger a prompt to save any SAS data sets that you imported into JMP and have not saved before closing. This option is selected by default.
Connect to CAS with SAS Viya Connections
Select this option to connect to SAS Viya with JMP. When connecting to SAS Viya, JMP can automatically connect to CAS.
