Profilers > Introduction to Profilers > Profiler Platform Options
Publication date: 01/13/2026
The Profiler red triangle menu contains the following options:
Profiler
Shows or hides the Prediction Profiler.
Contour Profiler
Shows or hides the Contour Profiler.
Custom Profiler
Shows or hides the Custom Profiler.
Surface Profiler
Shows or hides the Surface Profiler.
Mixture Profiler
Shows or hides the Mixture Profiler.
Show Formulas
Opens a JSL window showing a script for all formulas being profiled.
Formulas for OPTMODEL
Creates code for the OPTMODEL procedure in SAS. Press Ctrl+Shift and then select Formulas for OPTMODEL from the red triangle menu.
For more information about the following options, see “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP:
Redo
Platform Preferences
Save Script
Note: Additional options for this platform are available through scripting. Select Help > Scripting Index. In the Scripting Index, you can also find examples for scripting the options that are described in this section.
