Publication date: 01/13/2026
Project Workspace
In a JMP project, you can see all currently open files in the Workspace tool panel. Reports appear under the corresponding data table. The active data table appears in bold.
Tip: To hide or show the Workspace tool panel, select Project > Show Workspace. To specify which tool panels appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panels.
In the Workspace tool panel, you can perform the following tasks:
• Double-click a file to make it active.
• Right-click a file to close it, hide it (removes the tab and dims the file name), bookmark it, and more.
