Publication date: 01/13/2026
R Examples
This section contains examples of sending a data table to R, creating objects in R, and more.
Send a Data Table to R
This JSL example initiates an R connection, sends a data table to R, prints it to the log, and closes the R connection.
R Init();
dt = Open( "$SAMPLE_DATA/Big Class.jmp", invisible );
R Send( dt ); // send the opened data table represented by dt to R;
R Submit( "print( dt )" );
Create Objects in R
This JSL example initiates an R connection, creates an R object, retrieves the object into JMP, and closes the R connection.
R Init();
R Submit(
	L3 <- LETTERS[1:3]
	d <- data.frame(cbind(x=1, y=1:15), Group=sample(L3, 15, repl=TRUE))
R Get( d ) << NewDataView;
Use R Functions and Graphics
This JSL example initiates an R connection, sets the graphics device to a filename, plots to that file, and then opens the file to get the image.
R Init();
img_path = Get Path Variable( "TEMP" ) || "r_plot.png";
R Execute( {img_path}, {}, "\[
png(img_path)
plot(1:10)
dev.off()
plot = Open( img_path );
rc = Delete File( img_path );
Simple Matrix Addition in R
This JSL example initiates an R connection, sends a matrix to R, creates a matrix in R, adds them together, returns the new matrix to JMP, and closes the R connection.
R Init();
X = J( 2, 2, 1 );
R Send( X );
R Submit(
	X                                     #prints X to the log
	Y <- matrix(1:4, nrow=2, byrow=TRUE)  #makes a 2x2 matrix object Y
	Y                                     #prints Y to the log
	Z <- X + Y #matrix object Z is addition of X and Y
Z = R Get( Z );
Show( Z );
Bootstrap Sample
The script JMPtoR_bootstrap.jsl in the sample scripts folder performs a bootstrap simulation by using the JMP to R Project integration.
The script produces a JMP window that asks the user to specify a variable to perform bootstrapping over. Then the user selects a statistic to compute for each bootstrap sample. Finally, the data is sent to R using the R interface in JSL.
The boot package in R is used to call the boot() function and the boot.ci() function to calculate the sample statistic for each bootstrap sample and the bootstrap confidence interval.
The results are brought back to JMP and displayed using the JMP Distribution platform.
