Publication date: 01/13/2026
Recent Files in Projects
In a JMP Project, you can open a file from the Recent Files tool panel.
Tip: To hide or show the Recent Files tool panel, select Project > Show Recent Files. To specify which tool panels appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panels.
Open a file
In the Recent Files tool panel, double-click on a file or drag it into a project.
Note: Open files that are saved to the project contents do not appear in the Recent Files tool panel.
