Publication date: 01/13/2026
Red Triangle Options in the Dashboard Builder
The Dashboard Builder red triangle provides options such as running the dashboard, previewing the dashboard, and saving the dashboard as an add-in.
Run Dashboard
Starts the dashboard.
Preview Mode
Displays a preview of the dashboard. Click Close Preview on the dashboard to return to the dashboard mode.
Start Over
Remove objects from the workspace and select a new template.
Show Grid
Displays dotted grid lines on the workspace.
Show Properties
Shows or hides the Objects and Properties panels for editing display boxes. For more information about editing properties, see “Application Builder Window” in the Scripting Guide.
Auto Scroll
Automatically scrolls horizontally or vertically as you drag an object near the edges of the workspace. Auto scroll is selected by default.
Dashboard Mode
Deselect to display the dashboard in Application Builder, where you can fully customize the application and write scripts. See “Creating Applications” in the Scripting Guide. Select Dashboard Mode to return to the dashboard.
Source Panel
Shows or hides the Sources panel (the left column in which report components are displayed) and categorizes the icons. Show Sources is selected by default.
Save Script
To Data Table
Saves the script to the data table that was used to produce the report. This enables you to run the script again from the data table to re-create the results.
To Journal
Saves a link in a journal window that runs the script for the analysis. If a journal window is already open, the script is added to that journal window. The script contains the path to the data table. Note that if the data table cannot be found, the script does not run.
To Script Window
Opens a script editor window and adds the script to it. If a script window is already open, the script is added to the bottom of that open window.
To Add-In
Lets JMP users install the application and launch it from a JMP menu. See “Compile Scripts into an Add-In Using Add-In Builder” in the Scripting Guide.
To Template
Saves the application as a template from which you can create new dashboards. The templates are saved in the following locations based on your operating system and JMP version:
• Windows (JMP): "C:\Users\<username>\AppData\Roaming\JMP\JMP\19\DashboardTemplates"
• Windows (JMP Pro): "C:\Users\<username>\AppData\Roaming\JMP\JMPPro\19\DashboardTemplates"
• Apple macOS: "/Users/<username>/Library/Application Support/JMP/19/DashboardTemplates"
