Using JMP > Enter and Edit Your Data > Enter Data in Data Tables > Replace Missing Values with Previous Values in Data Table Columns
Publication date: 01/13/2026
When a column contains missing values, you can replace those values with the value in the preceding cell. For example, if “4, .,., ., ., 6, ., ., 7, .” is selected, the values are changed to “4, 4, 4, 4, 4, 6, 6, 6, 7, 7”.
1. Select the cells that contain the missing and replacement values.
The first cell that you select must immediately precede a missing value. After that, you can select nonadjacent cells.
Figure 4.5 Missing Values
Missing Values
2. Right-click and select Fill > Replace Missing with Previous Value.
Figure 4.6 Replaced Values
Replaced Values
