Basic Analysis > Text Explorer > Text Explorer Platform Options > Report Options in Text Explorer
Publication date: 01/13/2026
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
