Profilers > Excel Profiler > Resolution of Profile Lines
Publication date: 01/13/2026
The Default N Levels option on the Prediction Profiler red triangle menu affects the resolution of the profile lines. Note the following settings:
• This option defaults to 17 when the Profiler runs a model stored in Excel.
• This option defaults to 41 when the model is stored directly in JMP.
If the same model is stored in both Excel and JMP, then the profile lines can appear differently when the models are profiled. Increasing this value causes the Excel Profiler to run slower.
