Publication date: 01/13/2026
Result Table
Marker Annotation Position
The chromosomal location of each marker, provided that you specify an annotation table that lists the chromosomal locations of the markers. If you do not supply any position information, the column number of each marker in the input JMP table is listed instead.
With Marker Annotation Position
The chromosomal location of each comparison marker, provided that you specify an annotation table that lists the chromosomal locations of the markers. If you do not supply any position information, the column number of each comparison marker in the input JMP table is listed instead.
Distance between Marker Pairs
The distance between pairs of markers. If you do not supply any position information, the number of columns between each comparison marker in the input JMP table is listed instead.
Count
The total number of individuals that are observed for each marker.
Missing Proportion
The proportion of the individuals that are missing data for each marker or pair of markers.
Genotype Count
The number of genotypes that are observed for each marker.
Allele Count
The number of alleles that are observed for each marker.
Minor Allele
The allele at each marker that occurs less frequently.
Most Common Allele Coded as Zero
The allele at each marker that occurs most frequently. Individuals homozygous for this allele are coded as 0 for that marker.
Minor Allele Frequency (MAF)
The MAF represents the proportion of the minor allele for each marker in the observed population. This example assumes there is a biallelic marker locus M with alleles M1 and M2. A sample of N individuals of even ploidy k can therefore have k + 1 different genotypes at the locus. The number of individuals with i (i = 0, 1, 2, …, k) copies of allele M1 and j (j = 0, 1, 2, …, k) copies of allele M2 is denoted by Nij. The number n1 of copies of allele M1 can be found directly by summation: n1 = 0 × N00 + 1 × N10 + 2 × N20 + … + k × Nk0. The sample frequency of allele M1 is written as p1 = n1 / (k × n), the frequency of allele M2 is written as p2 = 1 - p1, and the sample frequency for each genotype carrying u copies of allele M1 and v copies of allele M2 is written as Pij = Nij / n.
Polymorphism Information Content (PIC)
The PIC (Botstein et al. 1980; Hilderbrand et al. 1992) measures the probability of differentiating the allele transmitted by a given parent to its child given the marker genotype of father, mother, and child.
Equation shown here
Heterozygosity (HET)
The heterozygosity, sometimes called the observed heterozygosity, is the proportion of heterozygous individuals in the observed population.
Equation shown here
Allelic Diversity
The allelic diversity, sometimes called the expected heterozygosity, is the expected proportion of heterozygous individuals in the data set when HWE holds.
Equation shown here
Degrees of Freedom for HWE
The HWE degrees of freedom are calculated using the formula Equation shown here, where k is the number of alleles found for a given marker that is being tested.
Chi-Squared for HWE
Under ideal population conditions, the two alleles that an individual receives, one from each parent, are independent, soPii = p12, Pjj = p22 and Pij = 2p1 p2 (i and j = 0, 1, 2, …, k). The factor of 2 for heterozygotes recognizes the fact that M1 / M2 and M2 / M1 genotypes are generally indistinguishable. This statement about allelic independence within loci is called Hardy-Weinberg equilibrium (HWE). Forces such as selection, mutation, and migration in a population or nonrandom mating can cause departures from HWE. The chi-square goodness-of-fit test that you can use to test markers for HWE (null hypothesis of Pii = p12, Pjj = p22, and Pij = 2p1 p2) is:
Equation shown here
Chi-Squared for LD (ChiSQLD)
The chi-square statistic provides an estimate of the strength of the measures of linkage disequilibrium by using the composite linkage disequilibrium (CLD) coefficient (Weir 1979). This method does not require the assumption of HWE and uses only allele and two-locus genotype frequencies.
Equation shown here
For biallelic markers, k and l = 2, and this test has 1 degree of freedom.
Composite LD (D)
The measure of the composite linkage disequilibrium (CLD) coefficient (Weir 1979), which does not assume HWE, and is written as follows: D12 = p12 + p1/2 - 2p1 p2, where:
– p12 is the frequency of gamete M1 M2.
– p1/2 is the joint frequency of alleles M1 and M2 at two different gametes.
– p1 and p2 are the frequencies of alleles M1 and M2 at two loci [Weir 1996].
Standardized Composite LD (D’)
The ratio of D to Dmax (Zaykin 2004).
Equation shown here
LD Correlation Coefficient (r)
A correlation coefficient that assumes values from -1 to 1 indicator variables indicating the presence of the two loci.
Equation shown here
P-value associated measures
Four columns of p-value-associated measures (PValue, Logworth (log10 p-value), FDR PValue (False Discovery Rate p-value), and FDR Logworth) of the strength of the chi-square test for HWE and/or linkage disequilibrium.
