Using JMP > Save and Share Your Data > Create Journals > Save Journals in Other Formats
Publication date: 01/13/2026
You can save a journal in another format (such as HTML or PDF). When you save the journal as HTML, buttons and links are active when the file is viewed in a web browser.
Note: The header and footer that are defined in your printer setup appear in the PDF file. However, you can set the left, center, and right header and footer in a JSL script. Search for the Set Print Footers message in the JMP Scripting Index. (Select Help > Scripting Index in JMP.)
Windows
1. Select File > Export.
2. Select the format.
See Save Reports.
3. Click Next.
4. (Optional) Rename the file.
5. Save the file.
Apple macOS
See Save Reports.
3. Click Next.
4. Name and export the file.
