Publication date: 01/13/2026
Set or Lock Factor Values
If you press Alt (Option on Apple macOS) and click in a profiler, a window prompts you to enter specific settings for the factor.
Figure 2.6 Continuous Factor Settings Window
For continuous variables, you can specify the following:
Current Value
The value used to calculate displayed values in the profiler, equivalent to the red vertical line in the graph.
Minimum Setting
The minimum value of the factor’s axis.
Maximum Value
The maximum value of the factor’s axis.
Number of Plotted Points
Specifies the number of points used in plotting the factor’s prediction traces.
Show
Show or hide the factor in the profiler.
Lock Factor Setting
Locks the value of the factor at its current setting.
