Using JMP > Platform Presets > View Preset Code
Publication date: 01/13/2026
View Preset Code
To view the JSL code behind a preset, select the Platform Presets button Image shown here, and then press Shift and select Customize Menu.
The presets for the current platform are displayed. Select a preset to see its code.
You can edit the code of the presets that are in My Presets.
