DRAFT help
Publication date: 01/13/2026
Close Multiple Files
On Windows, close several files at once from the JMP Home Window. Select the files in the Window List, right-click, and select Close. To keep a single file open and close all other files, select the single file and then select Close All But This.
On Apple macOS, select File > Close Multiple and then select the files that you want to close.
