DRAFT help
Using JMP > Combine and Present Reports by Using Dashboards > Combine JMP Reports by Creating a Dashboard
Publication date: 01/13/2026
With Dashboard Builder, you combine reports to create your dashboards without writing JSL scripts. Similar to Application Builder, Dashboard Builder has a drag-and-drop interface but with preconfigured display boxes. In Dashboard Builder, the display boxes do not require customization like they do in Application Builder. You can put reports and graphs in tabs, embed database queries, save the dashboard as an add-in, and more.
You can also quickly create dashboards by combining several open windows by using the Window > Combine Windows option. For example, you might combine two reports and a data table to arrange them on a dashboard. See Example of Combining Windows to Create a Dashboard for an example.
