DRAFT help
Design of Experiments Guide > Compare Designs > Compare Designs Options
Publication date: 01/13/2026
The Compare Designs red triangle menu contains the following options:
Advanced Options > Split Plot Variance Ratio
Specify the ratio of the variance of the random whole plot and the subplot variance (if present) to the error variance. Before setting this value, you must define a hard-to-change factor for your split-plot design, or hard and very-hard-to-change factors for your split-split-plot design. Then you can enter one or two positive numbers for the variance ratios, depending on whether you have specified a split-plot or a split-split-plot design.
Save Script to Script Window
Creates the script for the design comparisons that you specified in the Compare Design window and places it in an open script window.
