DRAFT help
Scripting Guide > Compatibility Notes > Compatibility Issues in JMP 18.0
Publication date: 01/13/2026
Application Data Folder Location
The location where preferences and add-ins are stored changed in JMP 18.0 on Windows. The location on macOS did not change. This change has particular relevance for add-ins.
On Windows, prior to JMP 18, all add-ins for all versions of JMP were stored in:
C:\Users\<username>\AppData\Roaming\SAS\JMP\Addins
In JMP 18 that location changed to:
C:\Users\<username>\AppData\Roaming\JMP\JMP\Addins
When JMP 18 is first launched on Windows, add-ins from JMP 17 and earlier are copied to the new JMP 18 location.
Because add-ins are copied to a different location, changes made to an add-in at JMP 18 do not effect the original add-in installation at JMP 17 (or earlier). For example, a recent file list is not shared with earlier versions, and uninstalling an add-in at JMP 18 will not uninstall it for prior versions.
