DRAFT help
Essential Graphing > Contour Plots > Contour Plot Platform Options
Publication date: 01/13/2026
With the options in the Contour Plot red triangle menu, you can tailor the appearance of your contour plot in JMP and save information about its construction.
Show Data Points
Shows or hides (x, y) points. The points are hidden by default.
Show Missing Data Points
Shows or hides points with missing y values. This option is available only if Show Data Points is selected.
Show Contours
Shows or hides the contour lines or fills. The contour lines are shown by default.
Show Boundary
Shows or hides the boundary of the total contour area. The boundary is shown by default.
Show Control Panel
Shows or hides the Alpha slider that enables you to change the Alpha shapes filter.
Transform
If the contour plot includes a Color role, the Transform option is enabled. See Additional Example of Contour Plots.
None
The triangulation is computed without any scaling to coordinates by using Delaunay triangulation. Delaunay triangles are computed to maximize the minimum angle of the triangles in the triangulation. This value is selected by default.
Range Normalized
The X1/X2 values are both scaled to [0,1] before computing the triangulation. If the X1/X2 limits are different, then this is a nonuniform scale. This option might be a better choice in cases where the X1/X2 units are very different.
Fill Areas
Fills the areas between the contours with a solid color. This option is the same option that is available in the Launch window. If you leave it deselected in the Launch window, you can see the line contours before filling the areas. See Fill Areas in Contour Plots.
Label Contours
Shows or hides the label (z-value) of the contour lines.
Fit to Window
Specifies the stretching behavior of the report.
Change Contours
Enables you to set your own number of levels and level increments. See Customize a Contour Plot.
Save
Contains options to save information about contours, triangulation, and grid coordinates to data tables. See Contour Plot Save Options.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
