DRAFT help
Using JMP > Import Your Data > Import Data from SAS > Create SAS Transport Files in SAS from JMP
Publication date: 01/13/2026
JMP can open SAS transport files that were saved by using the SAS XPORT engine. For example, the following code is sample SAS code that creates a transport file called test:
Note: misc and work are SAS libref names.
data test;
input name $ age weight;
cards;
Susan 12 72
Melanie 10 68
Jonathan 11 77
Sheila 13 67
libname misc xport 'C:\test.xpt';
proc copy in=work out=misc;
run;
