DRAFT help
Using JMP > Customize Menus and Toolbars > Customize Menus and Toolbars for Add-Ins
Publication date: 01/13/2026
To add new features to JMP, you can write the scripts and compile files to create an add-in. One way to compile the scripts is to use Add-In Builder as described in “Compile Scripts into an Add-In Using Add-In Builder” in the Scripting Guide.
Add-In Builder provides a menu editor that enables you to create menu items in the Add-Ins menu. You can also use the JMP Menu Editor to create menu items and add toolbar buttons for an add-in.
