DRAFT help
Basic Analysis > Distributions > Distribution Platform Options
Publication date: 01/13/2026
The Distributions red triangle menu contains options that affect all of the reports and graphs in the Distribution platform.
Uniform Scaling
Scales all histogram axes with the same minimum, maximum, and intervals so that you can easily compare multiple distributions.
Stack
Changes the orientation of the histogram and the reports to horizontal and stacks the individual distribution reports vertically. Deselect this option to return the report window to its original layout.
Arrange in Rows
Opens a window that enables you to specify the number of distribution reports that appear in a row.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
