DRAFT help
Using JMP > Enter and Edit Your Data > Organize Data in Data Tables > Edit or Delete Cells in Data Tables
Publication date: 01/13/2026
To edit or delete the contents of a cell, follow these steps:
1. Click the cell that contains the value that you want to edit or delete.
2. Press Delete.
3. To edit the value, click the cell a second time, and then edit the cell’s value.
