DRAFT help
Using JMP > Workflow Builder > Additional Examples of the Workflow Builder > Example of Adding to a Workflow from the Enhanced Log
Publication date: 01/13/2026
In this example, add steps to a workflow from the Enhanced Log.
1. Select File > New > Workflow.
2. Select Help > Sample Data Folder and open Iris.jmp.
3. Select Yes from the Record Action pop-up window.
4. Select Graph > Graph Builder.
5. Select Sepal length and drag to the X zone.
6. Select Sepal width and drag to the Y zone.
7. Click Done.
8. Close the Graph Builder window.
9. Open the Enhanced Log and click View > Log (Windows) or Window > Log (Apple macOS).
10. Select the Report snapshot: Iris - Graph Builder row.
11. Right-click and select Save Script > Add to Workflow.
Adding the step from the Enhanced Log is an alternative to recording, adding from the JMP Log History, or using the platform Save Script > to Workflow option.
