DRAFT help
Profilers > Excel Profiler
Publication date: 01/13/2026
Excel Profiler
Visualize Models Saved in Microsoft Excel
The Excel Profiler is used to visualize models (or formulas) stored in Excel worksheets. You can install the Excel Add-In when you install JMP.
Figure 9.1 Example of a Prediction Profiler Using an Excel ModelĀ
Contents
Overview of the Excel Profiler
Example of an Excel Model
Run the Excel Profiler
Use Linear Constraints
Resolution of Profile Lines
Use the Excel Profiler from JMP
