DRAFT help
Reliability and Survival Methods > Fatigue Model > Fatigue Model Platform Options
Publication date: 01/13/2026
The Fatigue Model red triangle menu contains the following options:
Fit Box-Cox Loglinear Sigma
Fits a Box-Cox Loglinear Sigma model, which specifies the fatigue-life distribution as a function of the fatigue-strength setting. When you choose this option, you specify one or more distributions for the fatigue-life variable. A separate model is fit for each specified distribution.
Fit Box-Cox-S Fatigue-Strength
Fits a Box-Cox-S Fatigue-Strength model, which specifies the fatigue-strength distribution as a function of the fatigue-life variable. When you choose this option, you specify one or more distributions for the fatigue-strength variable. A separate model is fit for each specified distribution.
Fit Box-Cox-N Fatigue-Strength
Fits a Box-Cox-N Fatigue-Strength model, which specifies the fatigue-strength distribution as a function of the fatigue-life variable. When you choose this option, you specify one or more distributions for the fatigue-strength variable. A separate model is fit for each specified distribution.
Fit Coffin-Manson
Fits a Coffin-Manson model, which specifies the fatigue-strength distribution as a function of the fatigue-life variable. When you choose this option, you specify one or more distributions for the fatigue-strength variable. A separate model is fit for each specified distribution.
Fit Coffin-Manson Zero Elastic Slope
Fits a Coffin-Manson Zero Elastic Slope model, which specifies the fatigue-strength distribution as a function of the fatigue-life variable. When you choose this option, you specify one or more distributions for the fatigue-strength variable. A separate model is fit for each specified distribution.
Fit Basquin (Inverse Power)
Fits a Basquin (Inverse Power) model, which specifies the fatigue-life distribution as a function of the fatigue-strength setting. When you choose this option, you specify one or more distributions for the fatigue-life variable. A separate model is fit for each specified distribution.
Fit Nishijima
Fits a Nishijima model, which specifies the fatigue-strength distribution as a function of the fatigue-life variable. When you choose this option, you specify one or more distributions for the fatigue-strength variable. A separate model is fit for each specified distribution.
Fit Rectangular Hyperbola
Fits a rectangular hyperbola model, which specifies the fatigue-strength distribution as a function of the fatigue-life variable. When you choose this option, you specify one or more distributions for the fatigue-strength variable. A separate model is fit for each specified distribution.
Fit All Models
Fits all individual models for all supported distributions.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
