DRAFT help
Publication date: 01/13/2026
Fit Life by X
Fit Single-Factor Models to Time-to-Event Data
The Fit Life by X platform enables you to analyze lifetime events when only one factor is present. You can choose to model the relationship between the event and the factor using various transformations, or create a custom transformation of your data. You also have the flexibility of comparing different distributions at the same factor level and comparing the same distribution across different factor levels.
Figure 5.1 Scatterplot That Shows Varying Distributions and Factor LevelsĀ
Contents
Overview of the Fit Life by X Platform
Example of the Fit Life by X Platform
Launch the Fit Life by X Platform
The Fit Life by X Report
Summary of Data
Scatterplot
Nonparametric Overlay
Comparisons
Results
Custom Relationship
Fit Life by X Platform Options
Additional Example of the Fit Life by X Platform
