DRAFT help
Publication date: 01/13/2026
Image shown hereFixed Effects Tests
The Fixed Effects Tests report in the Mixed Model personality provides a significance test for each fixed effect in the model. The test for a given effect tests the null hypothesis that all parameters associated with that effect are zero. An effect might have only one parameter as for a single continuous explanatory variable. In this case, the test is equivalent to the t test for that term in the Fixed Effects Parameter Estimates report. A nominal or ordinal effect can have several associated parameters, based on its number of levels. The effect test for such an effect tests whether all of the associated parameters are zero.
The Fixed Effects Tests report contains the following columns:
Source
The fixed effects in the model.
Nparm
The number of parameters associated with the effect. A continuous effect has one parameter. The number of parameters for a nominal or ordinal effect is one less than its number of levels. The number of parameters for a crossed effect is the product of the number of parameters for each individual effect.
DFNum
The numerator degrees of freedom for the effect test.
DFDen
The denominator degrees of freedom for the effect test (the degrees of freedom for error). By default, DFDen is calculated using the Kenward-Roger first order approximation. See Statistical Details for the Kackar-Harville Correction.
F Ratio
The computed F ratio for testing that the effect is zero.
Prob > F
The p-value for the effect test.
